1994 e320 misfire at idle and light acceleration? but clears up at WOT?
Old Aug 17, 2012 | 09:08 PM
monte383sbc's Avatar
94 e320
Arrow 1994 e320 misfire at idle and light acceleration? but clears up at WOT?
iam workin on my mothers 1994 e320 and she suddenly got a misfire, i put new plugs and wires in and still missfire, cleaned IAT and mass air flow sensor, i started pulling wires one at a time and play around wit the electrical connectors to the coil and iam having a issue the the power/signal wire that go's to the first ignition coil, that supplys spark to cylinder 2 and 5, i verified that all the coils were good by swapping them around, the car run slightly rough at idle and the idle will surge up and down at times, also if your driving the car under a load or wide open throttle the misfire goes away and clears up, also at idle when the engine is misfiring fuel smell and slight black smoke from the exhaust system which is telling me its getting fuel just not getting burnt. does anyone have a ignition wire diagram and can pin out the wire harness anf follow wire to fine a broke wire? i really needa figure this out asap cus this is my mother only ride and they are broke she just got layed off from her job and also my father did, so iam trying to help them out the best i can, the only thing i didnt do is a compression check and swap around injectors, any help is apprciated thanks matt
Old Aug 18, 2012 | 12:15 AM
neanderthal's Avatar
Do a search for code reader. The parts can be purchased at Radio Shack cheaply. It will take ten minutes to make it, ten minutes to read the codes. At most.
How is the wiring harness?
Old Aug 18, 2012 | 10:09 AM
94 e320
the injector/coil harness looks to me it was replaced its wrapped up nice and wire tied down, thats telling me sumbody was in there at one time, i noticed a few wires on the firwall are starting to delaminate and the copper wire is starting to show, iam starting to lean towards its a bad valve orfuel injector, i will dig into it more asap
Old Aug 18, 2012 | 12:02 PM
WDB124066's Avatar
1996 E320 Sportline Cabriolet x 2
Has the wiring loom been replaced. If not now is a good time to do it before the ECU is damaged.
Old Jun 10, 2013 | 12:03 AM
TomForm's Avatar
E320
i have the same ise with my 96 i replace the spark plugs an checked the wires for spark. it made it a little better when idle. but it still acts like it has a misfire. i was told it might just be a sensor.
