500E W124 LH low voltage /open circuit
Old Feb 23, 2013 | 07:13 PM
Mb500e93's Avatar
500E 93; C200 07
Can't start the engine. If I turn the key for 10 secs, there will be couple of backfires. SDS HHT tool shows "LH1, LH2 - do not answer". Please help
Old Feb 24, 2013 | 12:23 AM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
Does it have the original wiring harness?
Old Feb 24, 2013 | 05:56 AM
Mb500e93's Avatar
500E 93; C200 07
Upper wiring harness is brand new 2012
Old Feb 24, 2013 | 10:22 AM
Mb500e93's Avatar
500E 93; C200 07
Brand new ETA also in 2012. All fuses on base module inside computer box seem intact. Tried to give extra power by jump cabling through a G500 running. No help
Old Feb 25, 2013 | 02:24 PM
Mb500e93's Avatar
500E 93; C200 07
Any other ideas? Anyone??
Old Feb 28, 2013 | 11:02 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Happened to me recently and it was as easy as a slightly unplugged Crank Position Sensor near the top of the driver-side engine head. Towards the front of the car.
Next guess would be cap & rotors. They are sort of a wear and tear item on the M119 engine.
Old Mar 23, 2013 | 02:23 PM
Mb500e93's Avatar
500E 93; C200 07
Fixed it. It was either the cracked and ready to pulverize vacuum line to the ezl, or the caps and rotors. It could of course have been a loose connection to the cps, but I wouldn't know. Replaced the vac line and cleaned up the rotors/caps/plugs and it started beautifully. Would a bad vac line to the ezl by itself cause the engine not to start?
