I'm in trouble
Old Dec 3, 2013 | 08:29 PM
Whiskey124's Avatar
1990 300E
I'm in trouble
This morning on my way to school my car was running funny and it sounded like it had a vacuum leak. Leaving school this afternoon everything was fine until my ABS and SRS warning lights came on. Then the radio went, followed by the windows and HVAC. Finally the car started running poorly and died. I thought perhaps i blew a fuse and there was a burnt out fuse so i replaced it. i was able to start the car again after that but i stalled out again. I was not able to get it started for another 20 or so min. The fuse that i replaced was fine. Please help me. Thanks
Old Dec 3, 2013 | 09:27 PM
C3Duece's Avatar
2002 C32AMG
sounds like your alt is failing
Old Dec 3, 2013 | 09:46 PM
Whiskey124's Avatar
1990 300E
I put a meter across the battery this morning. It read between 13 and 16 volts (idle was pulsing like a vacuum leak)
Old Dec 3, 2013 | 09:49 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
It does indeed sound like a charging problem. The SRS and ABS modules both monitor the system voltage (right from the alternator field circuit) so they are often the first to come on in the event of a low voltage situation - the proverbial canary in a coal mine, if you will.
The most likely source of a charging problem is the voltage regulator/brush assembly. This is an easy R&R with the alternator on the car. I would check the system voltage with the car running - anything less than about 12.8 volts and it is probably not charging. I would also do this quick test - turn the key all the way to the "run" position, but don't star the car. You should get the "lamp check" where all the instrument cluster lamps come on so you can verify they are working (okay, who actually does that). Excluding the Check Engine light (if equipped), the ABS, and the SRS lights, if the rest do not illuminate, the brushes in the alternator (part of the voltage regulator assembly) are bad.
Good luck,
- FD
Old Dec 3, 2013 | 09:53 PM
Floobydust's Avatar
16 volts is too high if your meter is accurate. A variation over a large range like 13 - 16 tends to further point to a failing VR or perhaps a failing battery (internal intermittent causing to to go "open" under load).
Old Dec 3, 2013 | 09:54 PM
Whiskey124's Avatar
1990 300E
All annunciation panel lights come on when the key is first turned to the on position.
Adam
Old Dec 3, 2013 | 09:58 PM
Floobydust's Avatar
When the car wouldn't start for another 20 or so minutes, did it fail to crank over or did it crank over, but not start?
Old Dec 3, 2013 | 10:02 PM
Whiskey124's Avatar
1990 300E
Initially after dying it would not crank. Waiting 15 to 20 minutes would get it to crank over and reluctantly start.
Old Dec 3, 2013 | 10:09 PM
Floobydust's Avatar
Okay, that is most consistent with a failing VR. The car runs until the decreasing battery voltage causes a loss of spark or fuel pressure so it dies. Lead acid batteries exhibit some "self recovery" if let sit for a while (a la, 20 minutes), so the car could then be started.
Old Dec 3, 2013 | 10:20 PM
Whiskey124's Avatar
1990 300E
Ok I will pick one up tomorrow if I can. Thanks
Adam
