W124 dual fuel pump question
I have a 94 E320 and the fuel pump is leaking from somewhere on the pump. I saw some treads on replacing it but it seems most people only have one pump, mine has 2. So my question is, if I buy 2 new pumps, are they different? Or can I just order 2 of the same pump??
If you are correct and your model does in fact have two, they are connected in series and I believe they are very different----post your VIN for the correct pump numbers!
If i'm not wrong; need "2" pumps,,
58psi>>(4 Bar)..:) "ZAYED" |
Thanks for the response
Wdbea32e5rc052554 Is the vin
Originally Posted by chenzo benzo
(Post 6973722)
You are correct, with your VIN you would need two 003 081 53 91 fuel pumps and two valves 000 090 03 10:eek: |
