Fuse
Old Apr 8, 2004 | 02:34 PM
jst216's Avatar
1990 MB 300CE
Angry Fuse
I KEEP BLOWING THE #3 FUSE WHICH CONTROLS RIGHT SIDE TAIL LIGHT, RIGHT FRONT MARKER, ALL DASH LIGHTS AND OTHER ITEMS....CAN'T TRACK DOWN WERE THE SHORT IS...ANY HELP WOULD BE NICE.
Old Apr 8, 2004 | 05:17 PM
Sp!ke's Avatar
Sounds like a bad earth somewhere.
I'd check all the bulbs on the rear for a good clean contact and make look for all the earth points on the circuit and check for continuity/corrosion etc.
Old Apr 9, 2004 | 07:36 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Another try is to remove the bulbs one by one and see in which circuit the failure is located, then when you found out just check the complete wiring of faulty circuit.
Old Apr 30, 2004 | 09:49 AM
jst216's Avatar
1990 MB 300CE
CHECKED ALL CONNECTIONS AND GROUNDS, ALL GOOD, WORKED FOR A SHORT TIME. CAN HEAR SOMETHING JUST UNDER THE AIR CLEANER ASSEMBLY TRYING TO RUN, THEN BLOWS CIRCUIT BREAKER. THIS ONLY HAPPENS WHEN PARK OR HEADLAMPS ARE ON...ANY IDEAS. SERVICE DISC DO NOT SHOW ANYTHING ON #3 FUSE LEADING TO THE ENGINE COMPARTMENT....
Old May 6, 2004 | 08:10 PM
mike690003's Avatar
ex 300E driver
I dont know if you woulkd do this, but I have seen people put hight amp fuses in place to prevent the blowing.
