W124 1995 E320 Sunroof fuse
1995 E320 keeps blowing sunroof fuse.
It blows immediately after engaging the switch.
Tried a new switch with same result.
Sunroof is the only item on the circuit.
8 amp fuse.
8 amp fuse.
hallsa (06-22-2017)
hallsa (06-23-2017)
I forgot to mention that I can open and close the sunroof manually with the factory tool.
So, I assume it's going to be an electrical problem.
I'll see if I can remove the motor and check it and the relay.
