2.4 amp drain
Old Dec 30, 2017 | 08:22 PM
gregz1337's Avatar
1986 300E
2.4 amp drain
meter is reading 2.4 amp draw when connecting to negative cable and negative terminal with car off and negative cable disconnected.. is this normal? my car wouldnt start a week ago its really cold here my mechanic said i needed a new battery which I put in but I'm just confused. did the same test on my other 300e and its at 3 amps. my dads chevy truck reads 2 amps.
Old Dec 31, 2017 | 08:38 PM
gregz1337's Avatar
1986 300E
anybody....
Old Mar 1, 2018 | 10:35 AM
optimusprime m1's Avatar
W124 260E
First. Check output from alternator .. A reason of the voltage drop overnight is the regulator inside the altrrnator .
Old Mar 2, 2018 | 12:22 PM
teahead's Avatar
1994 e320 coupe
That seems like a lot. Wonder if it's the factory alarm? Or car stereo?
Start pulling fuses one at a time to isolate the circuit that's causing that huge draw.
