Would you be able to identify this tube? (e320)
Mercedes e320
Hello,
I am replacing my water pump and discovered this tube which seemed to be unattached to anything. Would anyone be able to tell me what this might go to and if it's important? My car is a '94 e320.
The location is above the A.C. compressor and close to where the belt tensioner assembly (removed) would be.
The water pump was located where the two studs can be seen above (and adjacent) to the tube in the second picture.
Thank you in advance for any replies.
Regards,
Tim
Close up of tube.
Tube located above a.c. compressor and sort of below the (removed belt tensioner assembly.
Regards,
Tim
Close up of tube.
