Suspected air/fuel ratio issue with a 94 E320
Old Apr 13, 2020 | 03:07 PM
TeeHeeTummyTums's Avatar
94 W124 E320, Ford Excursion Limited V10, 02 BMW E39 525i
Hello there! Sorry for the long and poor description, and I hope I'm not posting in the wrong forum. That's my first post.
I've a 1995 Mercedes W124 E320 with ASR/ABS. It idles fine but refuses to rev over about 2k rpm. If I press the throttle beyond that limit it starts to hesitate till it dies at wide open throttle. After many tests it seems like it's an air/fuel ratio issue that MAY be caused by Throttle Position Sensor (TPS). I've access to TPS wiring diagram. I'm not an expert, but it seems like this TPS is a 2 potentiometers connected in parallel. Here's a diagram exactly copied from the original diagram, and here are the readings using a multimeter set on 2K ohms. Do these readings indicate that there's a single potentiometer that's not functioning? And if so, if they're connected in parallel, does that affect the TPS functionality? Or do they back each other up? As I understand, the variable resistance tells the ECU the exact position of the throttle so it injects an appropriate amount of fuel. Sorry again for the long and poor description. Any input would be greatly appreciated!
Thank you very much!
Old Apr 13, 2020 | 08:31 PM
bicylindrico's Avatar
No clue on everything you just asked. You may want to try unplugging the Mass Air Flow sensor and see if it clears up. It wil use a fixed value instead of an erroneous one if it's bad. Good luck!
Old Apr 13, 2020 | 09:31 PM
Floobydust's Avatar
2018 GLE350, 2014 G550, 2000 SL500, 1980 TR8, 1995 E320 Cabriolet
Sounds like classic ecco-junk disease. All 94/95 W124s came with "biodegradeable" wiring harnesses which disintegrates over time. Both the main engine wiring harness and the Throttle Body Adapter (TBA) are affected. You need to check the date codes on these items - they must be 1998 or later. Search the various forums for where to check for the date codes. Until the ecco-junk wiring is replaced (both the engine harness and the TBA), you will never be able to diagnose the issue or get the car running correctly. Mercedes took a lot a heat for this issue, but never owned up to it. It's one of those little hidden time bombs in the W124 family.
Old Apr 13, 2020 | 10:36 PM
I did already ☹️ In fact, I went through everything I can think of. It's been a whole year and I'm frustrated.
Old Apr 13, 2020 | 10:42 PM
I checked the lower parts of the wiring, and indeed they were flaking off and brittle. I replaced all I could put my hands on, including the cps, oil pan sensor and starting circuit wiring. I stripped down the throttle body housing and wiring insulation, and the wires inside seems to be fine. I'll check the date though and inform you. I did test the magnetic clutch, servo, and the potentiometers. Everything works fine except for a single potentiometer that's not varying with throttle plate movement. That's why I suspect it might be the culprit.
Old Apr 13, 2020 | 10:50 PM
Here's a video that describes the issue. That fluctuation at idle increases in frequency if I rev it, till it dies at wide open throttle.
Video link Google drive
Old Apr 13, 2020 | 11:31 PM
Floobydust's Avatar
While the usual problem is the ecco-junk wiring, the potentiometers in the TBA do fail sometimes. I think either way, you are going to have to find a new (used) TBA with the later date code. I learned the hard way that you can't fix/rebuild the main engine harness. For each piece of cracked insulation that you fix, there are half a dozen more right behind it. It's a loosing battle.
Old Apr 13, 2020 | 11:41 PM
Well, that's super frustrating! ☹️ So, is there a way to convert it to say CIS from an m103 or even carb? I know it would be more inefficient, but what if all wiring is really toast, like it's not practical anymore to fix it? Just a guess...
Old Apr 14, 2020 | 07:11 AM
Floobydust's Avatar
Unfortunately, there is no other way to deal with it - like I said, it's the W124's dirty little secret that has put an end to many an otherwise fine car. I would suggest you find a good used harness and TBA on ebay or one of these forums. It would be a lot cheaper ans easier than trying to convert the fuel system to something else.
Old Apr 14, 2020 | 05:22 PM
A Speeduino setup would have that engine running perfectly for a few hundred bucks but one has to be savvy and able to put it all together. Add to it that you could actually tune your own engine and it would be well worth the effort. The older systems have become very disappointing and were never great when they worked. I agree with you, scrap it.
