reverse gear issue.
This is only remedied by an overhaul. If you drive in this condition for an extended period of time, you will damage the B-3 piston which is rather expensive. You´ll break off the positioning pin, due to its extra travel distance as a result of the worn clutch discs. You might even damage the planetary gears also, if severe dirt gets in between the wheels. And those are not cheap ! Let alone the valve body. -Bad news, I´m afraid.
The 124s are in my opinion rather bulletproof cars. When was the last time your fluid & filter was replaced ? Is there enough fluid in it ?
After having it rebuilt, all has been well for the last 40k miles, and have changed the fluid and filter 2 times since then. last time my mech saw the fluid and was like why am I changing this? the fluid still looks brand new, and I said just because you were under the car anyway so I figured why not do it.
AshMan
AshMan
There is slight difference in parts cost, though.
If you go for original clutches, you buy each disc individually and then there is the set of seals. All the rubber seals and the teflon rings should be included in that.
-A clicking sound in reverse indicates worn B-3 clutch. The B-3 piston travels too far because of the worn clutch and rubs against the K-1 clutch carrier. The B-3 retaining circlip and retraction springs might also be out of alignment.
