Recall on the W210 coming soon
Old Apr 8, 2005 | 12:01 PM
Air Marshall Eldritch's Avatar
John Deere
My service advisor just told me that MB will be sending out notices within a few weeks to replace the harmonic balancer wheel.
The wheel is composed of a rubber ring around a metal flywheel. Over time, the rubber cracks and breaks off the metal part. This causes the metal part to shift backward abruptly, rupturing the oil pan (which sounds like you'd have a bad day).
The replacement job runs several hundred dollars now, but of course will be free once the notices arrive in the mail.
fyi.
Old Apr 8, 2005 | 12:27 PM
Whitey's Avatar
98 W210 Advantgarde
fyi.
What years is this applicable to? Is it a worldwide thing? Thx.
Old Apr 8, 2005 | 12:34 PM
John Deere
Probably all W210 years. Not sure what regions, but if they used the same part in the non-US engine versions, then probably those as well. If I get more info, I'll post it here.
Old Apr 8, 2005 | 12:40 PM
Whitey's Avatar
98 W210 Advantgarde
Actually my 98 is starting to show some symptoms of what you had just described.... Just a couple of days ago, my mech said I'm most probably in need of a new flywheel or have it repaired or something .......
Please do keep us posted
Old Apr 8, 2005 | 12:56 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The 112/113 Engines V6/V8s will be the Victims
Old Apr 8, 2005 | 03:58 PM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
Well then it sounds like its not related to the brake/volt reg/batt issue on the 01-04 E's and other models.The MB people will have their hands full it seems.
Old Apr 8, 2005 | 04:50 PM
bingoldsby's Avatar
I wonder if I will qualify at all with a used car which didn't come from an MB dealer and for which I am not registered with MB so that a notice can be mailed to me. Curious what happens in that case.
I know I should contact the dealer, and will. But if they aren't going to deal with me because I don't have a legitimate notice which was mailed to me from MB, I'll be out of sorts.
Brian - Yakima, WA
2000 E320 - 91,000 mi.
Old Apr 8, 2005 | 05:00 PM
JoePaluch's Avatar
2003 ML320
Brian - Yakima, WA
In a recall notice the is covered if it has a VIN# in the list. It does not mater who owns the car where it was bought etc. The dealer get paid my Mercedes-Benz so as long as the say they did xxx work under recall on VIN#xxxx and it matches an recall notice by the factory they get paid.
There are two reasons to send notices. 1) Not all owners read these fourms and second is to try prevent the dealers and replacment parts supply to overloaded with everyone in 2-3 days.
Old Apr 8, 2005 | 05:09 PM
John Deere
To ensure you are registered as the current owner (so you get the letter), call 1-800-367-6372, and give the VIN to one of the reps. If you have been using a dealer for service however, you're probably already noted as the owner.
Old Apr 8, 2005 | 05:24 PM
bingoldsby's Avatar
Thank you very much to the last two responders. I'll attend to this matter soon.
Brian
Old Apr 8, 2005 | 05:31 PM
Top Jimmy's Avatar
'96 E320
Applicable W210s
I am pretty sure that this models will be '98 and newer.
The HB issues is very well know and a hot topic on some other boards. I stumbled across this issue after buying my '96 E320 but the more I read, it obvious that it was also in the W210s (and lots of Ms) with the V6s.
I believe '96 and '97 were the only years to retain the inline version and that the V6 became standard issue in the '98 models.
Old Apr 8, 2005 | 05:57 PM
bingoldsby's Avatar
... and soon it is.
I just talked to a gal at the 800 number given ablove - Mercedes Benz Customer Service line. I did get the correct information to them about me being the latest owner of the car.
She told me that she didn't think that this recall was going to affect E-Class cars back to year 2000, but I'd be notified if it was. Not much to do but wait and see. If, in the mean time, my balancer goes bad, it seems I'd be in a pretty good position for having a replacement made by MB.
Brian
Old Apr 8, 2005 | 06:10 PM
John Deere
According to the notice, it covers '98 to '00
I got this from a post on another forum where the service writer actually posted the details.
