1997 E-420 Type of engine oil
Old May 14, 2005 | 02:45 AM
hadam's Avatar
2007 S-550, 2001 E-430 & 1997 E-420
Red face 1997 E-420 Type of engine oil
Hi, all my previous oil service my service shop puts Castrol 20W/50 oil. Today I took my car to new dealer in Santa Barbara, the dealer put Mobil 15W/40.
Is Mobil 15W/40 is ok for 1997 E-420?? I have always used before 20W/50.
Some of the research I did on web shows me that Mobil 15W/40 is for MB Diesel car.
Any feed back will be greatly appreciated.
Old May 14, 2005 | 02:53 AM
MB Fanatic's Avatar
4 wheels
Mobil One 15W/40 is more than fine with the engine, and in fact it might even be better than using that junk castrol oil. Mobil1 is a synthetic oil and is factory fill in all new Mercedes. I would use Mobil1 from now on if I were you.
Old May 14, 2005 | 03:00 AM
hadam's Avatar
Is Mobil 15W/40 Synthetic ???
Is Mobil 15W/40 synthetic? I thought 0W/40 is synthetic. I hate to use synthetic in my 97 E-420.
I believe Mobil 15W/40 is Minerial Oil.
Can you please check and let me. Thanks for your reply.
Old May 14, 2005 | 05:27 PM
Peteski's Avatar
'04 CL500 '08 ML320CDI
When I had my '97 E420 I was told by the dealer to specifically NOT use synthetic oil. That opinion has been seconded by my new guy - he's not a dealer, but he works on nothing but Benzes.
Old May 14, 2005 | 06:57 PM
MB Fanatic's Avatar
4 wheels
Sorry about the information guys. If you have the older engines like the 420, 300, or inline 6 320, then don't use synthetic. But if you have the V6 320, or the 430 then you should use synthetic.
Old May 14, 2005 | 10:36 PM
mysticblu999's Avatar
Mercedes AMG
why not the inline 6? i am running 0w-40 mobil1 now.
Old May 14, 2005 | 10:38 PM
Mercedes AMG
ohh my car is starting to feel alittle weak..... please tell me thats not the reason.... ohhhh
Old May 14, 2005 | 10:39 PM
Mercedes AMG
correction. i am running 10w-30 mobil1
Old May 15, 2005 | 01:59 AM
HTBenz's Avatar
I use Castrol Synthetic blend(synthetic and conventional mix) 20/50 and one bottle of Lucas oil stabilizer. I have the inline 6 also.
Old May 15, 2005 | 02:05 AM
Mercedes AMG
i was using swepco 15w-40 it was a half and half. i used it since i got the car in 2003 and just wanted to change to a fully synthetic oil...
Old May 15, 2005 | 02:36 AM
hadam's Avatar
So, Do I conclude that Mobil 15W/40 is fine for my 97 E-420. It is V8 engine 119 and tranny is 722 [W210] ????
Old May 15, 2005 | 02:39 AM
MB Fanatic's Avatar
4 wheels
Yes this oil is more than adequate for your car. check out the Mobil1 Website and see what they reccomend.
Old May 15, 2005 | 02:47 AM
hadam's Avatar
Exclamation change oil every 7500 miles as recommended by MB or should I do it every 3000 Miles.
MB Fanatic, Thanks for your feed back. I am very new to German cars. I got one more for you, What should be the period between oil changes, should I change oil every 7500 miles as recommended by MB or should I do it every 3000 Miles.
Any feed back will be appreciated.
Old May 15, 2005 | 03:18 AM
MB Fanatic's Avatar
4 wheels
I would stick with the 7500 mile intervals. Today's oils are designed not to be changed at 3K miles. You wont have anything to worry about, except you will be saving some money.
