MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   E-Class (W210) (https://mbworld.org/forums/e-class-w210-2/)
-   -   Boost Car's Performance (https://mbworld.org/forums/e-class-w210/109738-boost-cars-performance.html)
98MBE320 May 31, 2005 07:14 PM
I have a '98 E320 4Matic and want to enhance my car's power performance without breaking the bank. Any suggestions?
Thank you.
lexrex May 31, 2005 07:24 PM
For more HP, sell your E320 and buy an E430 or E55. The E430 was available with 4matic starting in 2001. You can buy a performance ECU chip for your 320 for less than $1k that will give you a few extra HP, but I'm personally not convinced it does anything good for the longevity of your motor. Replacing your spark plugs & air filter may improve performance if these items are worn. You can buy a performance exhaust system, but they usually give up low end torque for high RPM power.
For better handling, replace any worn suspension rubber and swap out the stock rims/tires for 17" 235/45/17 or 18" 235/40/18. It's tough to find suspension mods on the 4Matic b/c of the unique front suspension (front axle shaft runs through the coil spring).
© 2026 MH Sub I, LLC dba Internet Brands
