Climate control fan on 97 e320
Old Jul 11, 2005 | 08:15 AM
butch199's Avatar
The fan on my 97 e320 stops working intermitently. I have checked all fuses. Is there a relay or some other control that could be causing the problem? When working the fan seems to run OK.
Thanks for the help
Old Jul 11, 2005 | 09:49 AM
E-Klasse's Avatar
W205 C300
Sounds like it could be the speed regulator that is mounted on the fan motor.
Old Jul 11, 2005 | 11:05 AM
SmokeSilver's Avatar
1997 E420
Agreed...this sounds like the fan regulator. Just had mine replaced. The no longer make the exact part for this year e class. However, the S Class one works just fine. Pray that your fan is ok, as that piece is big $$$. The regulator cost me about $400 installed.
Works like a champ now...
