Replaced trans. fluid and...
Old Feb 18, 2006 | 02:29 PM
king_j's Avatar
i have a 97 E320 with 70k miles.
has a sealed transmission.
changed the fluid at a dealer, it shifts fine when driving, but when starting cold, its not sure what gear to be in. it changes from 2nd - 1st and vice-a-versa. it only does this sometimes, and when it does it its very quick.
before i had the fluid changed, it never did this.
if the dealer used the regular trans fluid, not the lifetime, would that cause this problem?
Old Feb 20, 2006 | 03:22 AM
purplegrog's Avatar
2012 C250
I don't know the answer to the first question, but afaik, the red mb fluid is the same as the yellow, except the red has the red dye in it. If I'm wrong, someone please feel to correct me.
