ball joints
Old Apr 8, 2006 | 12:38 PM
2quik's Avatar
ball joints
2001 E430, already need ball joints, with 40,000 mi. Anyone else or is it just my luck? is there any recall on this?
Old Apr 8, 2006 | 02:03 PM
livetodrive's Avatar
2001 E-430 4-Matic
At my annual inspection last month, the dealer replaced the lower ball joints under the extended warranty. I have 48,000 miles on the car. Make sure you get a wheel alignment once they're done.
Old Apr 8, 2006 | 05:04 PM
2quik's Avatar
why would u need a wheel alignment? Your not touching any of the suspension components
Old Apr 8, 2006 | 05:34 PM
Little's Avatar
2001 E430 4matic
Whats the symptoms of this?? As of the past month, if i step on the brakes goin slow and come to a quick stop i hear a thump up there.
Old Apr 8, 2006 | 09:06 PM
2001 E-430 4-Matic
Why Do a Wheel Alignment?
I had bought four new tires with a wheel alignment last October. In February, two months later, I had the car inspected at the dealer. During the inspection they replaced the lower ball joints but didn't give the car a wheel alignment. The tires were fine at the time of the inspection (they had to be good to pass the inspection). Their reason was the same as yours - not needed. Another two months went by, and I went under the car to replace a broken foglight lens. Both front tires were ruined due to inside wear. In fact, the steel belt protruded from one tire. The tires had 2,000 miles on them. Between the dealer and the tire shop I received two new front tires, with a wheel alignment!
Moral of the story: have a wheel alignment done after replacing the ball joints.
PS - they're Pirelli P Zero Neros. They're great - quiet, handle excellent, and are all season tires.
