wheel vibration?
Old May 18, 2006 | 07:42 AM
Gomez153's Avatar
97 e320
wheel vibration?
i have h-r springs and 19 staggered brabus replica's made by rennen on my 97 e320 and my front end vibrates at high speeds and especially when im braking it's pretty bad i took my passenger side front of and it seems like my disc had a lil play could it be loose or is this normal? suck's when you have someone in the car big pimpin and you hit the brakes and there like DAMN what the hell is that?
Old May 18, 2006 | 12:21 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Sounds like you have TWO problems
Vibration at speed is NOT related to Vibration When Brakes are applied
Are the rims Hub centric?Rims checked for runout? Spacers Installed? Tires checked for Runout? Decent shop Balance the rims ON the car? Also Inspect the Lower control Arm Bushings This is for The Vibration at speed
Vibration when Brakes applied sounds like a Brake rotor is defective
Have the brake rotors measured for runout..Do NOT resurface the rotors
Just replace the defective rotor/rotors..also look into CYRO treatment for the rotors..it helps the rotors last several tims longer
