E320 Brake Light
Old May 27, 2006 | 08:25 PM
Jambazman's Avatar
1998 Mercedes Benz E320
E320 Brake Light
My 1998 E320 right brake light is not working. I swapped bulb holders and eother will work in the left side. I disconnected harnes connector, sprayed contact cleaner on connector and mating surface where bulb holder mates up and still no brake light. I am out of ideas, does anyone have anything else I could try?
Thanks.
Mark
Old May 27, 2006 | 08:51 PM
ehr1's Avatar
2002 E55 AMG, chevy truck,1984 190E(race car)
You are going to need a new tail light assembly. What happens is the heat
from the bulbs melts the plastic lense assembly from the metal contacts.
This causes the bulb holder to not make good contact with the metal contacts.
hope this helps
Old May 28, 2006 | 01:37 AM
Thrillhouse's Avatar
I think you can get LED brake light assemblies on ebay.....seems like a good idea, just hope they put some kinda resistor inline
Old May 30, 2006 | 10:26 AM
E320Star's Avatar
2000 E320 Sedan
CHECK THE FUSE BOX
