Early W210 Blower Motor Regulator Replacement DIY Here...
Old 12-27-2012, 08:14 PM
  #251
faller's Avatar
E-430
Mine works all summer then when it gets cold it doesn't work or works sometimes. I have a 2000 E430. Ordered a new regulator (new version). Put it in today and it didn't work. Unplugged it plugged it back in and it worked. Then the climate control wouldn't turn it down from full blast. Kept doing this for a while. I would work with the controls sometimes then it wouldn't. I gave up and came in and read this forum for a while. Thought it might be the Climate control unit itself. I was one click away from buying one and I figured I should pull the old one first. Then i figured I might as well put the old regulator back in with the blower motor seeing as that probably wasn't it. So I did and now I get nothing at all. So I go to touch the red wire where it goes into the motor itself and it comes on. So I try the CC controls and everything is working normal. I figured I found the loose wire maybe I can solder it etc. So I try bending the two wires where they go into the motor every which way in order to make it stutter or stop but nothing. It just work all the time now. I figure I found a loose wire. It's been working perfectly since. I may also have brushes that are going. If it stops again I'll replace the motor. So if you have erratic operation it could be the motor not the climate control unit. Basically this was a very long way of saying I found a loose wire on the motor and I couldn't be happier.
Old 01-18-2013, 09:01 PM
  #252
misterbigge's Avatar
2001 clk320
I replaced the regulator in my CLK320 and it did not fix the problem so I replaced the fan/motor assembly. Still not working right. A MB mechanic told me there are a lot of problems with cheap replacement regulators. I bought a Behr regulator (from autohausAZ) and now it blows my toupee off.
Old 01-19-2013, 10:26 AM
  #253
AMGDave's Avatar
300D, 500E, E420
Do you remember what brand regulator it was that did not work properly?
Old 01-19-2013, 11:49 AM
  #254
2001 clk320
Dave, it was a Metrix brand regulator from discountmbparts.com that I bought for $63 that never did work. I paid $95 for the Behr unit that works great.
Old 01-20-2013, 07:12 PM
  #255
qbaum's Avatar
Rookie needs help
New to the forum. Here is where I am...
1996 E300D, 175K
AC blower stopped. Found this thread and ordered the W124 regulator from deutschepartsusa
Plugged and played without cutting and splicing to be sure regulator would solve the problem.
Turned on climate control.... JOY TO THE WORLD !!!! the blower works.
Everything is working fine and I am feeling very proud.
Went for a ride and fan stopped. After a mild stroke, I parked it for the night to let my BP settle.
Next morning, climate control works... for a while... then it stops again.
Stroke a little stronger this time.
Fast forward through a couple of more cycles of this... and here I am.
I have 12v to the red and blue wires to the motor with fan control on max.
Took the fan and hot wired it to 12 volt battery. She runs. Plug everything back up and BINGO... no voltage to motor. Unhook motor and I show 12v on the red and blue again.
Help?
Old 02-20-2013, 11:25 AM
  #256
benzoeclass's Avatar
1996 mercedes e320 3.2 2000 audi a6 twin turbo
works for me ordered great easy fix thanks
Old 02-24-2013, 10:29 AM
  #257
AMGDave's Avatar
300D, 500E, E420
Help?
Sounds like either the new regulator is defective, or your control unit is not sending a signal to the regulator. You'll need to check for control voltage at the input to the regulator to help determine which is the problem. Unfortunately I'm not familiar with the exact voltages to look for on the W210 chassis, maybe someone else knows the typical control voltage at min and max blower speeds...?
Old 05-01-2013, 04:17 PM
  #258
rocketman766's Avatar
1999 mercedes e320
1996 E300D, 175K
Help?
Did you find the problem? I have the same issue but I have tried 2 additional new regulators and blower motors and they still don't work. Must be something else! Any help would be appreciated!
Old 05-16-2013, 08:29 AM
  #259
greatbranch's Avatar
e320
Regulator replaced
Had the problem about 2 years ago on a 96 E320. Got the S140 regulator for about $37.00 at WWW.thepartsbin.com
Used wire splices and all works well still.
Old 05-16-2013, 09:12 AM
  #260
treiberg's Avatar
2003 C230 and 2005 C230
If you look around you should be able to find one that doesn't require splicing. Bought mine on ebay for $59 and it already had the wiring in place and was a simple drop-in replacement. Took about 5 minutes to replace once I had the blower out, total job was less than 30 minutes.
Old 05-25-2013, 09:47 PM
  #261
rthiebaud's Avatar
1998 E320 W210
Brilliant! I'm slow (hampered by seat that won't adjust back - and it only took about two hours to complete this project - cost for the part was 25 on eBay. I couldn't wait on a USA part as I go on vacation in two days - driving! Anyway, again, Brilliant!
Old 06-02-2013, 12:01 PM
  #262
mister mers's Avatar
96 w210, 03 e500
W210 9094302385 regulator
No splicing, direct replacement for 9094302385 , just for $50, worked for me on on 96 w210
Old 07-06-2013, 09:06 PM
  #263
sammyf's Avatar
2007 GL450 (Gone), 2014 E350, 2014 GL63
If anyone is interested... I bought a regulator for my W140 and it came with 2 adapters - Don't need the one for the W210. $35 shipped CONUS? Otherwise its going into the trash.
This one for the W140:
Early W210 Blower Motor Regulator Replacement DIY Here...-8b069f0e-e06e-4f84-89bc-857317967d22-1166-00000108e6eb8f2e.jpg
This one for the W210?
Early W210 Blower Motor Regulator Replacement DIY Here...-c7fde766-9aa7-4807-aa10-ee7e95de9863-1166-00000108ee6b43f1.jpg
Old 08-02-2013, 08:18 PM
  #264
pjconfarm's Avatar
98 MBZ E320
have a 98 E320 that the blower fan has quit - is there a part that we can order that does not require the splicing of the wires? Know that we have an early W210, and that we need the W140 from the S class.
Old 08-04-2013, 10:36 AM
  #265
mbmaniac's Avatar
e320
http://www.ebay.com/itm/New-Mercedes-Blower-Motor-Resistor-Regulator-9094302385-MB-W210-E320-E420-E300-/281030805151?pt=Motors_Car_Truck_Parts_Accessories&hash=item416ebdc69f&vxp=mtr will work for 98 w210, it worked for me without any splicing.
Old 08-05-2013, 10:16 AM
  #266
Airetime's Avatar
Made in China? Stick with Bosch
Originally Posted by mbmaniac
This one will work for 98 w210, it worked for me without any splicing.
Might work for a little while but you would be better off installing the Bosch part. Kind of nasty if you have 100 degree weather and it quits, how much is that worth?
Old 08-05-2013, 08:19 PM
  #267
pjconfarm's Avatar
98 MBZ E320
that did not work - oh well, see what else it might be.
Old 08-06-2013, 08:55 AM
  #268
96 w210, 03 e500
didn't get it, what went wrong? it is all the same to original one.
Old 08-06-2013, 01:14 PM
  #269
pjconfarm's Avatar
98 MBZ E320
The new one is about 1/2 the size but bolted up and plugged in with no trouble, the old one is like the one above that sammyf showed pix of
Old 08-16-2013, 11:35 AM
  #270
blueC230K's Avatar
2002 W210 M112 | 2021 X247 M270 | 2015 Audi SQ5 | 2015 VW Golf R
Hey all,
My 2002 A/C was blowing very weak so I ordered the blower regulator Had that replaced and it worked for a bit. After a month or so, I turn on the A/C again. Nothing come out at all! I checked the fuse and they look good. Do you think it's because the new regulator is not compatible with the blower motor or the motor is just bad? Anyway to check this? Thanks in advance!
Old 08-16-2013, 06:45 PM
  #271
96 w210, 03 e500
Check current on the fan. Also, it is good idea to ground the fan.
Old 09-30-2013, 06:58 PM
  #272
jeffreygiles's Avatar
1999 MB E300 TD
Great instructions
I just changed the blower motor and regulator using this thread. What a help! I also change all the cabin filters. I found that Importec had the parts cheaper than anyplace else when getting a non-oem blower motor. The part works great and we saved over $800 from what the dealer wanted to charge to replace everything.
Jeff
Old 11-10-2013, 02:55 PM
  #273
mrboca's Avatar
98 E320, 02 LS430
1996 E300D, 175K
Help?
Maybe the overheating problem? Sounds like the regulator is overheating due to either clogged cabin filters or improper installation. It is important to clean up the metal and remove all the gunk prior to bolting the regulator. Sometimes people use too much thermal paste which prevents good metal to metal heat exchange, and the the regulator overheats after some use, or with the reduced air flow through the blower metal frame. It is likely that a thermal protector opens up the signal line from the climate control (almost zero volts to the output transistor base) and this switches off the regulator. After the unit cools down the thermal protector resets to conduction. and the unit works again. Advice would be change your cabin filters when you change the regulator, and use the thermal paste sparingly (just to fill in the microscopic surface "potholes" on both surfaces (frame, and the heatsink base of the regulator. Also the regulator bolts must be properly tightened to ensure good surface to surface heat transfer.
Old 01-01-2014, 11:09 AM
  #274
rrahe's Avatar
'98 MB e320 Wagon W210
Smile Perfect fix!!
I followed the post and installed the W140 regulator in me '98 e320 wagon, and it worked perfectly!!
Hopefully I'll get another 157000 miles out of it!! 19.95 free ship off of ebay. It's worked for a month, no problems...
Old 01-02-2014, 11:03 AM
  #275
tbone006's Avatar
E320
RRAHE --- Nice!!!!!!!
Ya man..this Forum saved my life! otherwise i woulda lost my mind or sold my Benz a long time ago!!! Glad everything worked out for you
You have already rated this thread Rating: Thread Rating: 14 votes, 5.00 average.
Quick Reply: Early W210 Blower Motor Regulator Replacement DIY Here...
