The "S" and "W"
Does anyone know if there is any difference in gas mileage if you use "W" or "S"?
I hadn't driven in "S" in a long time, but tried it recently. My 1999 E-320 usually has a bit of a jolt when shifting from 1st to 2nd, when in "S" mode. Is this normal? In "W", the car was very smooth when shifting.
W = wet
In my W210 cars, the W position yields the following:
- Earlier upshifts
- car starts in 2nd gear
- hill-holder function
- softer action from torque converter
- lower reverse gear
- great for low speed crawling while stuck in major traffic tie-up
Some have said there "should" be an improvement in fuel economy, others say hogwash.
The transmission is provided with a selector switch for Standard "S" and Winter/Wet (snow and ice) "W" program modes.
Standard Mode
Press switch on symbol "S". Use this mode for all-regular driving. The vehicle will start out in 1st gear.
Fast On = Depressing the accelerator pedal quickly (not into kickdown position) while driving continuously, rather than depressing the accelerator pedal in the usual manner, will cause the automatic transmission to shift down into a lower gear. This gear shifting process is dependent on the current vehicle speed.
Fast Off = There will be no upshift when releasing the accelerator pedal quickly, e.g. using the engine's braking power during performance driving.
Winter/Wet (snow and ice) Mode
Press switch on symbol "W". The vehicle starts out in 2nd gear, except with selector lever in 1st gear, or with accelerator pedal in kick down position.
The "W" mode helps to improve traction and driving stability of the vehicle. The gear shifting process occurs at lower vehicle and engine speeds than in the "S" program mode.
Caution! Never change the program mode when the selector lever is out of position "P". It could result in a change of driving characteristics for which you may not be prepared.
Important! Always be certain of the program mode selected since the vehicle driving characteristics change with the selection of the program mode. Dependent on the program mode selector switch position "S" or "W" and the gear selector lever in position "R", the ratio of power transmission changes.
