Where are the Hi and Low sides on the A/C and the Drier
Old Jul 29, 2007 | 01:35 PM
Max Hughes's Avatar
Where are they, i think i found the hi side but wheres the low side? A diagram would be nice. Also i would like to know the location of the drier.
Old Jul 29, 2007 | 06:28 PM
ohlord's Avatar
Smile Follow the yellow brick road
I jest...
welcome Matt
why are you asking about the drier,a/c not working? have you run the onboard diagnostics?
ohlord
"GOT CODES?"
Old Jul 29, 2007 | 06:48 PM
ohlord's Avatar
Reverse is also true
follow the line from the evaparator to the compressor that is the low side line.It has the small fitting so you can't goof it up adding r134a the tube will only fit on the low side port,sort of runs along from the right side of the block back to the firewall,plainly visible on the aluminum tube.
get back here if you haven't run the tests,and if the a/c is not working,lots to check before you toss in more a/c gas
ohlord
"GOT CODES?"
ohlord
Attached Thumbnails Where are the Hi and Low sides on the A/C and the Drier-ac_layout.jpg
