MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   E-Class (W210) (https://mbworld.org/forums/e-class-w210-2/)
-   -   Sunroof won't close (https://mbworld.org/forums/e-class-w210/204047-sunroof-wont-close.html)
GeorgeThompson Aug 1, 2007 07:11 PM
Sunroof won't close
Hey Guys,
I opened my sunroof today and now it wont close. No response or noise when pressing the button. Not very good timing either. I have an appointment to have the car looked at for a trade in. Is there a way to manually close the sunroof. Could it be caused by a blown fuse. If it is a blown fuse which one would it be. Any help would be GREATLY appreciated!
Semikolon Aug 1, 2007 07:33 PM
I'm not sure where you can find the sunroof fuse, but there is a fuse box on the drivers side of the dash when you open the door. there's a cover which you can easily open with a flat screwdriver, knife or even your bare fingers. you can also check the main fusebox which is located near the battery. the battery is located under the passengerside back seat.
sunroof is probably listed in one of the boxes. replace all blown fuses. but be aware there might be a reason why they are blown. so if a fuse blows when you replace it, or when you use for example use your sunroof, high beam lights or whatever, there is something wrong and theres no point in replacing the fuse again before you have fixed the problem.
ohlord Aug 1, 2007 08:55 PM
Try the key lock function
Hold the key to lock doors and keep holding it a few seconds more and see if the sun roof closes,if not pop off the dome light cover drivers side ,the one that comes on when you open the door,and insert an allen wrench,found sometimes inside your glove box,of the proper size and crank the roof closed.sell it private youll get more for it.
ohlord
"GOT CODES?"
Fill in your profile as to year and model,welcome to the forum!!!!!!!!!!!!!!
Musikmann Aug 1, 2007 09:10 PM
Allen wrench
Originally Posted by ohlord (Post 2349873)
...pop off the dome light cover drivers side ,the one that comes on when you open the door,and insert an allen wrench,found sometimes inside your glove box,of the proper size and crank the roof closed.
OMG Ohlord, I have been wondering what that twice bent allen wrench in the glove box is for, so thanks fot the info my friend!
ohlord Aug 1, 2007 09:46 PM
I wonder how many people
Have just sh*t canned that wrench thinking oh what would I ever need that odd looking thing for?At least it doesn't throw a code,when they:D toss it.
ohlord
"GOT CODES?"
coach z Sep 27, 2007 06:54 PM
Has anybody come up with a solution to this one. I have the same problem with my 210. It opens just fine but won't close, tried the switch, the remote, key in the door nada, closie it manually and it opens again fine but won't close WTF??? I know the motor is getting power and the sunroof is running fine in the track.
Any help is much appreciated:smash:
ob1kenobi Sep 27, 2007 07:29 PM
You sir are a very valuable member of this forum.
I've read a lot of your response and most of them help out folks
with their problems.
Thank You.
ohlord
"GOT CODES?"
xlr8tin Sep 28, 2007 09:01 AM
Get your codes reset. :smash:
E420SportGT Sep 28, 2007 02:18 PM
/scrambling to my car to see if I haven't accidentally thrown out that allen wrench/ BWHAHHA
lisaclk320 May 19, 2014 10:47 AM
Reset Codes
How do you reset the codes ?
© 2026 MH Sub I, LLC dba Internet Brands
