Cell Phone Antenna Cap
Just bought one
litchfield auctions mentioned above is back on e-bay. the price is up to $32 now for just the black rubber cover. i hope it works. the quote i got from my mb dealer was $850 to purchase and install entire gps antenna assembly on my 00 e 430 4matic. $32 seems worth a try---thanks
2001 E430, Obsidian Black w. Ash/Orion Grey, 195,000 mi.
You'll need to trim a little rubber off the bottom and enlarge the hole in the plastic antenna base a little. I used a 9/16 drill bit but you can use a pocket knife, too.
Fred
enlarging the hole in the cover to
2000 E430 Sport
Check the body / trim DIY stickies on benzworld.
Replaced mine Monday (paid $11 at the dealership for part number 202 827 00 31 as above). Just call the dealership and ask if they have it in stock - no need for them to know why. If they dont have it then they can order it.
Used a knife to enlarge the hole in the painted cover little by little (trim - test fit, trim - test fit), pushed the tip through to the third groove, and trimmed the bottom of the rubber tip (while still in the housing). Dont enlarge the hole on the painted cover too much as you can ruin it. All you need is a small allen wrench, knife, and back to black. Took 10-15 minutes.
Note - The black trim at the bottom of the painted housing may be brittle - mine is cracked so I used some "back to black" (on the rubber tip and trim) and re-assembled. I dont know if this trim can be purchased separately from the painted housing. Just use back to black on the rubber tip / trim when you wash your car to avoid further cracking / drying out.
#32
+1
Fred
#33
Interesting
My local dealer in Tampa told me I had to purchase the entire cap & Boot. Gave me the part#210827 0031 color code 9744 price of $128.70 has anyone gotten the $6 part on line ? As I'd like to buy more than one but not at the $128 price !
#34
I bought mine here. It includes the rubber mast cover as well as the rubber gasked for the roof. Fit perfect and only $25 + ship. http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories
#35
1 Post
2001 E320 - RIP
the kit includes the rubber tip and the rubber gasket. the tip on mine was missing and the rubber gasket fell apart when i removed the antenna mount - best bet, if the gasket is original then it's no good and you should replace it too. with the new tip you'll need to drill out the hole a little bit for it to fit snug all the way and sit flush.
got mine here, $32.60 shipped.... http://cgi.ebay.com/ebaymotors/2001-2002-2003-Mercedes-Benz-E320-Antenna-Mast-Cover-/310198391885?cmd=ViewItem&pt=Motors_Car_Truck_Part s_Accessories&fits=Make%3AMercedes-Benz|Model%3AE320|Year%3A2001&hash=item483943d44d
#36
This worked for me.
I've replaced mine with rubber cap+gasket from these guys:
http://www.partsgeek.com/catalog/200...enna_seal.html
(Their prices, though, seems to be creeping up ever so slightly over
the years....I seem to remember it being only $15 or so when I first
ordered them several years back.)
Car washes pretty much rippes these things off the roof so I've had to
replace mine about two or three times now.
Hope this helped.
tsh
Hope this helped.
tsh
