Help Please!! Trans or what??
Good luck in sorting this all out. I owned a W124, 400E, and the kick-down was always problematical; I know what a pain [and potentially a danger] that can be when you need to get going fast.
JR
JR
the trans may be affected by the same leak if the trans vac line is mated to the same fitting.
http://w210.pietrzyk.net/trans_functdiag.htm
http://w210.pietrzyk.net/trans_general.htm
check all vac lines to the transmission.
ohlord
most trans codes would start with P07 or P08.
ohlord
Just posted a diy for the egr cleaning on benzworld.org w210 section.search p0400
ohlord
found it
http://www.benzworld.org/forums/w210...questions.html
ohlord
found it
