Damn.. A light is out
Old Aug 16, 2008 | 10:02 PM
MBE430!'s Avatar
E430
Hi,
Recently the light behind my unit that controls the air inside of the car went out. The one that has the climate control..
Any idea how I can fix that light.
I hope it is not to hard or expensive.
I drive a 2000 E430 4-matic.
Thanks.
Old Aug 16, 2008 | 10:37 PM
ohlord's Avatar
Easy
you need the radio keys that are also used for the climate control.PM me for delivered on the boxed set cluster hooks and keys for when you lose a cluster bulb also.
you insert the keys pull the climate module and on the bottom side is a tiny white twist out socket,you twist it out pull out the little bulb and replace it.
ohlord
Old Aug 17, 2008 | 08:33 PM
mike430sport's Avatar
2000 E430 Sport
climate control
On my 2000 the climate control display is going bad . The display now shows a bunch of black lines coing threw it when turned on. Is there a fix???
Thanx
Old Aug 18, 2008 | 12:42 AM
ohlord's Avatar
Like dead
liquid crystal numbers?If they are failing and you can't read them but the unit still works,it is only the display failing and a new module is the solution,or one from a wrecking yard.I can get a deal on new and will check some yards I have special access to.You can also check online at http://www.mbpartsonline.com/
ohlord
if you have a buddy with the same model,pull his unit with the radio/climate control keys,pm meand swap it out while he is not looking
Old Aug 18, 2008 | 08:54 PM
2000 E430 Sport
ohlord
Thats funny! Guess I need a new, or good used unit. It still displays and works fine. I just dont like looking at wild lines going through the liquid display.
Old Aug 18, 2008 | 10:11 PM
ohlord's Avatar
Post a pic
so we can see what lines look like.Odd display
