LED's
Anyone using LED's for interior / cluster lighting? Need to repalce a bulb in the cluster thought I would upgrade while I had it out. Looking for a source to buy as well. Thanks
Don't
but if you must.http://www.superbrightleds.com/cgi-b....20125&next=50
ohlord also pm raymond g he has done some int light mods. :bow: |
Originally Posted by ohlord
(Post 3060247)
actually, i've not done the LED on the interiors. not having read up on this,
i'd like to know of the cautions to this as well. the only LED mod i've done has been add LED to the rear license plate. i played around with EL light cords but didnt like the results so i pulled them. i was trying to create some- thing like the S series but failed to get a smooth, integral classy light in my E320 http://www.autospies.com/images/uplo...226-233301.jpg |
The light
when you can find on that fits and is the correct wattage,is to directional and the back lighting from the dash cluster looks bad.It's like how surprised you are the first time you pull the climate control cluster to replace the buld and you think how the heck can such a tiny bulb light up that whole display? single led would only light up the center.Since the actual diode is only the size of the head of a pin and the lens shoots the light out straight unlike the tiny incandescent bulb.
:bow: |
(Post 3060918)
:bow: |
I just did my dash with LED bulbs and it looks alot better than the old bulbs that were in there.
Mine you it took some experimenting buying different Leds to see what looked the best.:y |
Originally Posted by Benzs
(Post 3062404)
| All times are GMT -4. The time now is 07:33 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
