Bi Xenons vs. Depo Projectors
2003 S210 3.8L Brabus wagon
I have the OEM Xenon headlamps and recently saw a white European wagon like mine that has the Depo projector headlamps with the trim ring surrounds. On a white car it really looked nice. What are the thoughts about making the swap or not and why?
They are the factory oem xenons in the option package E1 for $1,150.00 with the headlamp washers. Did I misquote? That is off the original window sticker that I have.
That is the correct picture. I did misquote. Sorry for the confusion. It is Option package E1 includes headlamp wash system and xenon headlamps. I did change title of thread to correct my error. Any thoughts as to original question?
why?
- looks better (to many)
- upgraded design to more modern, 211 look
why not?
- Depo design woefully inferior vs 210 HID in terms of performance
- go get better lighting, you'd have to yank out the guts and substitute
E55, Maxima, or 211 bixenon projector (technically illegal)
- you'll lose the autoleveling feature
- 211 bixenon, clear lens headlight will not fit (PnP) the 210
https://mbworld.org/forums/e-class-w210/233395-depo-headlight-hid-projector-retro.html
http://www.benzworld.org/forums/w210...nversions.html
why not?
Thanks Raymond. I stayed up and read both threads. It looks like an involved project and cash outlay. What bulbs would you recommend to upgrade the existing OEM Xenons and also is there a high beam bulb upgrade that would give a brighter blue/white light than the stock yellowish? And while I am pestering do you recommend a driving light upgrade with a matched color to the xenons? Thanks again for staying up and helping a newcomer to this model.
2000 W210 E55// 2007 Toyota Tacoma X-Runner
You do have factory xenons..they are not bi, hence the bad high beam...to get a brighter high beams, might I suggest Silvania Silverstars. Your factory xenons are very good lights if properly adjusted.
'02 E430 SE, '02 Avalanche Z66, '06 R-350
According to the info when I purchased my 210 (2002), it has Bi-Xenon. The way I understand it, Bi-Xenon just means that the low beam xenon lights stay on when you turn on the high beams.
209/W210 Estate /W211 modded by MBENZNL
Bi Xenon Headlights were NOT offered on the W210
As Bi xenon headlights have a Low AND High beam that are Xenon..Most have a shutter that changes the light pattern..like a 203/211
The W210 only has a Xenon LOW Beam...
