Engine Swap (Now no Spark)
Old Nov 25, 2008 | 10:35 PM
illmeth0d's Avatar
2000 S430
I just put the part number in ebay search
Theres one on ebay for $99.99 , free shipping.
http://cgi.ebay.com/ebaymotors/96-97...Q5fAccessories
Heres another one for 149.99 that looks a little bit cleaner.
http://cgi.ebay.com/ebaymotors/ENGIN...Q5fAccessories
Also check out www.car-parts.com
Look under Engine Computer , then 210 Type, Throttle Cont, (R Rr eng comp), (E320 & E420) , they have them down to $45 dollars.
Old Nov 26, 2008 | 09:58 AM
cig3's Avatar
1997 e320
Old Nov 26, 2008 | 10:01 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Might want to open up the control unit and check for a loose connection or bad circuit board solder ...I Have seen bad solder connections on early fuel pump relays...It may work work you
Old Nov 26, 2008 | 02:34 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Jumper that overpriced blackbox and slap a Holley 750 double-pumper on.
It worked in "Dukes of Hazzard" (or was it Macgyver?)
Old Nov 26, 2008 | 02:56 PM
cig3's Avatar
1997 e320
Angry
<TABLE class=tborder id=post3178409 cellSpacing=0 cellPadding=6 width="100%" align=center border=0><TBODY><TR vAlign=top><TD class=alt1 id=td_post_3178409 style="BORDER-RIGHT: #cccccc 1px solid">OK now the dealer is telling me even if I find the ECM (Throttle Control) with the same number as mine that it will not work without the ignition, keys and locks from the donor car. They said if i buy the new part at $1100.00 is has to be programmed for my car and that you cannot program the module more than once. Is this all true? I'm quickly growing tired of this project.
Mark I am in agreement with you on the examining of the current module. I planned on doing it once I got the car up and running. Looks like I may have to do it this way regardless.
A.B.
<!-- / message -->
</TD></TR><TR><TD class=alt2 style="BORDER-TOP-WIDTH: 0px; BORDER-RIGHT: #cccccc 1px solid; BORDER-LEFT: #cccccc 1px solid; BORDER-BOTTOM: #cccccc 1px solid"> </TD><TD class=alt1 style="BORDER-TOP-WIDTH: 0px; BORDER-RIGHT: #cccccc 1px solid; BORDER-LEFT-WIDTH: 0px; BORDER-BOTTOM: #cccccc 1px solid" align=right><!-- controls --></TD></TR></TBODY></TABLE>
Old Nov 26, 2008 | 08:41 PM
A.B.
<!-- / message -->
Once a ME control unit is locked it CANNOT be recoded ..Just like the late keys once they are coded they are locked ...If You want to use a Used one you will need several items from a donor car EIS AND Keys and a ME Control unit...
Old Nov 26, 2008 | 10:10 PM
  #32
ohlord's Avatar
1997
m104 should not have the married system.You have a regular key not Ir. correct and your ecu is dead or dying?
One time use key can marry all the units together.MB charges a fee for the key that unlocks the ecu and links the system together.A 97 should not have that issue.
if they can tap it and make it run you can heat sink it and locate the loose contact and repair it.
Old Nov 27, 2008 | 07:37 AM
  #33
cig3's Avatar
1997 e320
Red face
I plan on trying to repair the current ecu.
Ohlord , If I'm reading your post correctly I should be good to use the used module I purchased. Correct... I would keep te original as a spare or vis/versa aftera successful repair.
What is the correct way to heat sink the module?????
A.B.
