W210 Black & White Series from Germany!!!
Old Mar 29, 2012 | 10:25 AM
  #326
Anatoli's Avatar
E500 estate
Thanks to all!!
@ tbone006: I made the panel by myself. The TFT is an Touch Screen, the CarPC is in the back of the car. Everything controlled by the Touch, incl. Internet, Telephone, Music, Video,...
The company of the steering Wheel is carsdream.com
The Carbon of the steering wheel mady by different company.
Old Mar 29, 2012 | 01:41 PM
  #327
tbone006's Avatar
E320
Console Panel
anatoli - That panel turned out AWESOME !!! I would love to see more pics of the construction of that panel and the relocation of your control buttons below it. Again brother ...GREAT JOB on your car, your hard work and efforts paid off !!! Thanks for responding about the panel construction - aloha !!
Originally Posted by Anatoli
Thanks to all!!
Old Mar 29, 2012 | 11:32 PM
  #328
Anatoli's Avatar
E500 estate
I will post later some pics about the panel work :-)
Old Mar 31, 2012 | 07:08 AM
  #329
Anatoli's Avatar
E500 estate
Here`s the CarPC
The Panel...
I cut the oem Panel in two parts and used the part of the top now at the bottom.
For that i had to shortening the sides for about 1cm.
The next problem was that the cutted panel hasn`t had an Radius at the bottom. So i cut from another panel the Radius and adhere it to the cutted panel.
Next step was to make an panel for the top.
My first idea was to use an oem panel for it, but the problem was that the two holes from the seat heater button would be see besides the TFT aperture. So i had to go on with "normal" board.
First cut in correct dimensions, then adhere to the bottom panel.
Next thing was to make the framke ready to hold the TFT and the clima console. Everything has to work like oem
Then i had to cut out some material from the panel for the TFT.
The last two pics shows the first fitting tests.
After all was correct fitted in the whole panel was send to the Carbon Fiber Factory, the endresult looks like that:
The clima control and also the whole panel are fitted in the same way as oem.
Old Apr 2, 2012 | 12:59 PM
  #330
tbone006's Avatar
E320
hahahaha....that is AWESOME !!! It turned out AMAZING better than stock !!!
- So did you have to extend or alter wiring for controls at all ?
- What type of glue / plastic filler / epoxy did you use?
- Also is that clear acrylic used for side-brackets?
WELL DONE !!!
Old Apr 2, 2012 | 07:05 PM
  #331
Anatoli's Avatar
E500 estate
Haha
No, the oem wires for the clima control and the "button Bar" is long enough so it wasn`t necessary to extend something.
I used i 2K Plastic Glue i found in the local Carparts Store, ist fantastic in holding, also you can sanding, drilling,...wonderful. And it harden very fast.
Yes, i ordered the acryl glass parts in eBay, no problem. They are very hard but light.
Old Apr 3, 2012 | 06:16 AM
  #332
toby1's Avatar
W210 2002 E320 CDi Avantgarde
Excellent work as always
Old Apr 5, 2012 | 03:33 AM
  #333
Anatoli's Avatar
E500 estate
Thank you :-)
Old Apr 14, 2012 | 10:00 PM
  #334
enrikerace's Avatar
WHITE E320 1999, GruppeM Intk, E55 TB, Evosport Pulleys, Longtube Cer. Coat Headers, Cat/res Delete
wow
Nice ride!!! TOTAL INVESTED???¿¿ can you calculate it??
Hope it runs as it LOOKS... ANY PEFORMANCE UPGRADE??
YOU DID AN AWSOME WORK...CONGRATS..!!!
Old Apr 15, 2012 | 09:31 AM
  #335
Anatoli's Avatar
E500 estate
Thank you enrikerace.
Performance upgrades are: ECU tune, VMax limiter is out and the gear box is programmed for faster shiftening - like the AMG have it.
Old May 6, 2012 | 09:08 AM
  #336
Anatoli's Avatar
E500 estate
I`ve got some new pics and one Update.
Now a have got Shift Paddles at my car
Special Thanks to Marko!!
And here is the youtube video how the paddles work:
Old May 6, 2012 | 09:28 AM
  #337
MBFLO's Avatar
2001 E55 - 2008 CLS63 -2016 F-150
You have outdone yourself again my man .. Wish you were here in the states would love to see that thing in person .. Should post this on AMG section too cuz there were guys asking how todo it and FML your the 1st one I seen .. Great job ..
Old May 6, 2012 | 09:52 AM
  #338
Anatoli's Avatar
E500 estate
Thank you :-)
The W210 AMG Section?
Old May 6, 2012 | 09:54 AM
  #339
MBFLO's Avatar
yea.. your shyt basically a w210AMG ..now all u need is the motor to complete it lol
Old May 6, 2012 | 09:57 AM
  #340
Anatoli's Avatar
E500 estate
No, the Motor will not follow :-)
A short Differential will follow, also the camshafts from an C43AMG and Cat deletion...with the Super+ ECU Tune i already have i am sure the E430 is as fast as the oem E55.
We will see - pics, videos and details will follow.
Old May 6, 2012 | 11:58 AM
  #341
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I don't think that will get you close to the power of an e55 with the mods listed. You will need a supercharger or turbo to make up for the 1+ liters of displacement difference. Awesome work on the car though.
Old May 6, 2012 | 12:07 PM
  #342
Anatoli's Avatar
E500 estate
I mean the W210 E55, not the W211 E55.
Old May 6, 2012 | 12:25 PM
  #343
BlownV8's Avatar
Yes, I'm talking about the 210 E55. It has 75 more HP and 100 lb/ft of torque more than the E430. You will need a supercharger or turbocharger to overcome that difference. A cam, tune, and exhaust will not get you close to those numbers.
Old May 6, 2012 | 02:05 PM
  #344
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I have a C43 and have installed the Evosport UD pulley kit, Phenolic spacers, Renntech CF air box, AFS pro dry s filters and have deleted the secondary and resonator. At my last dyno I was @ 246 RWHP (this was without the Renntech air box and filters, I am estimating 256 RWHP with the airbox) and I am not at W210 E55 power yet.
I have Kleemann headers, Random technology cats and a Eurocharged ECU tune I need to install but even then I am expecting to be around 280-290 RWHP which is what a stock W210 E55 puts down.
There is no replacement for displacement (unless we are talking F/I )
P.S. you have one of the best looking W210's I have ever seen!
Old May 6, 2012 | 05:32 PM
  #345
kccoop07's Avatar
2000 E55 AMG
Please tell us how the paddle shifters work! Are they just switches tied into the factory Touch Shift wiring?
Old May 7, 2012 | 03:06 AM
  #346
Boobo-oobo's Avatar
w210 220CDI
The paddle shifter install is my mod. I helped Anatoli, i made him the electronics and send it to him. I did a writeup here : http://www.benzworld.org/forums/w210...r-install.html
If you need any help, let me know. I can make you the electronics and explain everything in detail.
Old May 7, 2012 | 12:25 PM
  #347
Anatoli's Avatar
E500 estate
This user helped me with the installation
Old May 7, 2012 | 01:54 PM
  #348
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
Very nice W210 !
Old May 7, 2012 | 03:41 PM
  #349
Anatoli's Avatar
E500 estate
Thank you Charly
Old Jun 9, 2012 | 02:20 PM
  #350
Anatoli's Avatar
E500 estate
I`ve got a new Cam.
