comfert control panel
Old Apr 12, 2009 | 11:03 AM
ronnieb9580's Avatar
E320
The panel to change the temps and stuff isn't lit up anymore. In order to set the interior temps at night I need to turn on the doom light to see it. Is there a simple fix to get it to back light again?
It's a 98 e320
Old Apr 12, 2009 | 01:13 PM
TMAllison's Avatar
09' E320
You need radio removal keys to remove and replace the bulbs.
Old Apr 12, 2009 | 10:44 PM
E320
are the lights hard to replace once it's removed?
Old Apr 13, 2009 | 08:18 AM
BoS7463's Avatar
1997 Mercedes-Benz E420
its one bulb and its in a simple twist and lock base located at the bottom of the climate control unit
Old Apr 13, 2009 | 01:29 PM
ohlord's Avatar
I have
the cc /radio and cluster kit and the bulb.Pm me if you need a set to see the light
Old Apr 14, 2009 | 02:41 AM
stickygreen's Avatar
'97 E320
For the last couple months, my climate control backlight would not come on initially. After a couple light taps, the light would come on. Only in the last week has the light stopped working altogether. Indicative of a bad bulb or possible a loose connection?
OL...check your PM
Old Apr 14, 2009 | 03:31 AM
Semikolon's Avatar
2001 E220T CDI Avantgarde, 2002 E55T AMG
bad bulb...
Old Apr 14, 2009 | 05:17 AM
'97 E320
thanks...
