MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   E-Class (W210) (https://mbworld.org/forums/e-class-w210-2/)
-   -   temp. control panel won't light up (https://mbworld.org/forums/e-class-w210/292559-temp-control-panel-wont-light-up.html)
LarrysBenz Apr 14, 2009 02:01 PM
all small swithch lights work but main back light will not. and temp. fluxuates up and down when set at middle range, example, 75
thanks
TMAllison Apr 14, 2009 04:41 PM
Bulb is burned out. Need radio keys to pull head unit.
nsupra Apr 14, 2009 10:10 PM
You can buy the keys, and the little bulb at the dealer. They are both cheap. Easy fix.
mysticblu999 Apr 14, 2009 11:52 PM
i got my keys at walmart :)
LarrysBenz Apr 17, 2009 01:50 PM
THANKS GUYS, I THINK I CAN FIX THE LIGHT MYSELF BUT NOT SURE ABOUT THE TEMP. PROBLEM. WIFE SAID WHEN BOTH SIDS ARE SET AT 85, DRIVER-SIDE HEATS UP, PASS.-SIDE BLOWS COLD. ANY HINTS? 2000 E320 4MATIC.
THANKS AGAIN
LARRY
ohlord Apr 17, 2009 02:33 PM
Run the Onboard climate control
diagnostics and you will most likely discover the Duo-valve is stuck.
You can give them a tap(a firm drum like thump)with the end of a wooden screw driver handle.That usually frees it up,if not fixed then you can take it apart,clean it and lube it and problem solved.
Post your data values 1-8 only and errors in the error mode.Write them down to post here and then in error mode press both auto buttons at the same time to clear the error block.
:bow:
LarrysBenz Apr 18, 2009 02:07 PM
olord;
thank you. this is my first benz. guesss i'll have to buy a manual to figure out this stuff. thanks again. larry
ALEE May 3, 2011 02:56 PM
Hey BMers , what kind of bulb do i need to replace my backlight A/C control panel screen that burned out ?
any clue!!
ohlord May 4, 2011 12:53 AM
It is a tiny
bulb only attained online but by the time you pay shipping cheaper at the dealer.
You will need a set of radio keys to pull the cc module,flip it over ,twist out the socket and replace the tiny bulb,install back in and job complete:y
ALEE May 5, 2011 01:54 AM
THANKS
thank you for you help. but do you have any idea about what type of bulb light is in the back of the AC PANEL?
© 2026 MH Sub I, LLC dba Internet Brands
