Vacuum pump help!
Old May 1, 2009 | 09:36 PM
rennwerkes's Avatar
2001 E55, 2002 ML55, 2002 SL500, 2003 CLK55
Vacuum pump help!
Can anyone tell me if you can hear the vacuum pump under the rear seat running? Mine runs for a few seconds then stops then starts again.
Everything seems to be running fine in my car. Vents and locks are all good.
Thanks!
Old May 2, 2009 | 02:12 AM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
yes that is a perfectly normal sound to here once you turn the key to on. You are pressurizing the fuel system.
Old May 2, 2009 | 02:43 AM
rennwerkes's Avatar
Thanks but I think mine runs constantly.
Is that normal?
Old May 3, 2009 | 04:22 PM
iluvJesus's Avatar
2000 E320 RWD
perhaps check for leaks, any problem with doors or trunk?
Old May 3, 2009 | 05:45 PM
rennwerkes's Avatar
No, all good.
Old May 7, 2009 | 07:16 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
I don't hear mine running at all and I don't have any problems.
Old May 7, 2009 | 07:27 PM
rennwerkes's Avatar
Mine is loudest on start up. I guess it's pressurizing itself. Either there's too much ambient noise when I'm moving or the pump isn't running after start up. Going to ask my boy to listen more carefully when I get a chance.
Thanks!
Old May 7, 2009 | 07:54 PM
Musikmann's Avatar
I spoke without thinking that through. When I turn the key to position 2 (right before cranking) there is a slight "whirring" sound but that appears to come from the front somewhere. I should add that I have a minor hearing deficit so that might explain a mis-perception. You're welcome.
Old May 7, 2009 | 08:57 PM
saintz's Avatar
GL450
I believe the nav/COMAND system spins up a fan when you turn the car on. I believe that's the noise from the front. It appears to also run for a little bit after turning the car off.
The air pump also powers the multicontour seats in the E55 and some other cars that are equipped with it. Renn, do your seats (it appears you have an E55) inflate properly?
Old May 7, 2009 | 09:03 PM
rennwerkes's Avatar
Yup, seats inflate properly.
Old May 8, 2009 | 02:55 PM
usaims's Avatar
98 e320
My vacumm runs every two seconds for about two seconds but my locks work. How does on one check for leaks?
usaims
