ASR and ABS Warning Light.
Old Sep 7, 2009 | 10:06 AM
paqueras's Avatar
G320 CDI, C32 AMG Sportcoupe, GLK300 4MATIC
Wink ASR and ABS Warning Light.
I started the engine and in the dash appear this message ( ASR & ABS ).
Also the driving wheel is harder than usual, is there a relation with the other problem?
How can i turn off this message.
Ps: i did search!
Old Sep 8, 2009 | 08:33 PM
tpowel2's Avatar
2013 Ford C Max Energi, 2013 Cadillac SRX
Do you have brake lights? Have someone look while you apply the brakes, if not, then it could be your brake light switch. It's just above your brake pedal and is easy to change out.
Turn your steering wheel all the way from one side to the other and see if that resets the warning (but it will most likely come back on until you fix it).
Old Sep 12, 2009 | 08:07 PM
paqueras's Avatar
I scanned the ECU, and the code on the scanner was:
P1605 Acceleration Sensor.
The car only get to 4200rpm and then it starts to cut the fuel.
What the hell is happening? Limp Mode?
HELP!
