P1700 Code showing up
Old Sep 12, 2009 | 06:47 PM
Benzs's Avatar
E320 1996
Just started getting this P1700 code I have cleared the code twice so far in a week.
I noticed the tranny does not stay in lower gear for a longer time when cold.
Is this a upshift delay valve issue.
Anyone have this problem?
Old Sep 12, 2009 | 08:28 PM
TMAllison's Avatar
09' E320
That one is not on my list of MB DTC's. http://www.buellwinkle.com/MBOBD2.html
Is your generic OBDII scanner pulling it up?
Old Sep 13, 2009 | 08:12 AM
Benzs's Avatar
E320 1996
Yes it is pulling that code and my scanner is just a regular OBD11 type.
I have searched around for any info I guess it is not a very common code
Old Sep 13, 2009 | 11:16 AM
TMAllison's Avatar
09' E320
I suspect you are finding descriptions for other manufacturers and need to find MB's useage of that code to know what going on.
You might try using a different scanner and see if it can correctly pull up a MB code.
Old Sep 13, 2009 | 12:21 PM
ohlord's Avatar
P17XX
Range codes are Manufacturer specific.
You need to find an MB code reader capable of reading the TCM codes.
A P0700 or P1700 are indicating you have codes stored in the TCM and you need to get at those codes to find out what the issue is.
Any leaks,check around the electrical connector on the trans passenger side.
Old Sep 13, 2009 | 06:27 PM
Benzs's Avatar
E320 1996
There are no leaks anywhere around the tranny.
Have been under there changing the motor mounts and tranny mount recently.
Tranny fluid was changed in the spring.
I guess a trip to the indie to read the codes is next step.
Old Sep 15, 2009 | 08:27 PM
Benzs's Avatar
E320 1996
Well I cleared the code and I had another MAF as a back up,So I installed that and so far the code has not come back.
I am unsure if the MAF has anything to do with the tranny.
Old Sep 15, 2009 | 10:15 PM
TMAllison's Avatar
09' E320
PO170 would pertain, but you'd have to have reaffirmed the typo in 4 follow up posts for it to apply.
Old Sep 16, 2009 | 05:03 AM
Theropode 430T's Avatar
S210.270 & W201.018
In my case, when the MAF was "gone" the tranny wasn't changing gears smoothly anymore, ...
