rims spec will it fit on w210 e55?
Old Dec 21, 2009 | 12:35 PM
pinoyk20's Avatar
99 model w210 e55 amg
<HR style="COLOR: #cccccc" SIZE=1 itxtvisited="1">
im buying rims for my car with this spec front 19x8.5 offset 30. with 245/35/19 tires REAR: 19x10 offset 32. tires 275/30/19 tires are bridgestone re050a . it came form a w211 chassis. will it fit my e55 without rubbing issues? thanks
and will it clear the caliper? thanks
Old Dec 21, 2009 | 12:51 PM
ohlord's Avatar
A235 35 19 would be better matched to the rear
and would fit.The 10 inch rims on the rear are going to take some test fitting
W210 specs
E55: 18 x 8” ET31 front, 18 x 9” ET35 rear.
Tires 245/40ZR18 front, 275/35ZR18 rear
so you can see the 10 inch will be close dropping to a 32.
Test and try.
You will need special lugs,the w211 are different so you will need custom lugs from otis rad usa.
Hope you know your ride quality is going to nose dive.
good luck.See my recent post in the S class w140 forum here or on www.benzworld.org I posted Mercedes wheel and tire fitments,might have more info worth checking.
Old Dec 21, 2009 | 01:24 PM
pinoyk20's Avatar
oh ok so the lug pattern are different.....??? 235 on the rear? wow aint it to thin? thanks
Old Dec 21, 2009 | 03:13 PM
ohlord's Avatar
No 235
on the fronts will match the rear diameter wise and give you some wiggle room for clearance. Lug pattern is the same 5by 112 but the lugs are different lkength and seat shape. You pick up custom lugs from Rad/otis.
Got It
Old Dec 21, 2009 | 09:07 PM
pinoyk20's Avatar
thanks sir! what type of lugs will i be needin? thnaks
Old Dec 21, 2009 | 09:51 PM
ohlord's Avatar
Just tell rad otis when you order
that you are putting w211 rims on a w210 they'll know.
about 50 bucks a set.
I do not recommend 19's but that is up to you to ruin your nice ride and control.
Old Dec 22, 2009 | 10:15 AM
pinoyk20's Avatar
its not a w211 wheel its a LINEA CORSE LEMANS WHEELS
http://www.lineacorse.com/wheels_lemans.html
he got the width and offset customed. thanks
