Help- I need different LUGs - which ones?
TIA...
Darrin
https://mbworld.org/forums/showthrea...threadid=32212
Seems that the newer style wheels use a larger diameter and shorter lug bolt. One person in the post above indicates that the surface area of the "ball" or area where the lub bolt contacts the wheel is smaller when a 12mm lug bolt is used.
If the ball seat is the same, the angle or bowl curvature are the same, the 12mm C class lug bolts should work fine. If the wrong style lug bolt is used, ie: 60 degree cone to mount a ball seat, then you are asking for big trouble because the mounting contact area is greatly reduced.
Rob Lee
It seems like there should be an easier way....
