left rear is clicking??
1 Post
ml/e420/others
was putting my other wheel back on the car and had put the ebrake. now after i was done changing the tire and release the ebrake and drove the car im getting a real annoying/loud clicking noise from the left rear
i re jacked the car and checked my rear pads and there good the fronts are low.
98 Brilliant Silver E320 Wagon
As raymond points out it's the sound of lug bolts hitting internals of rear brake drums.
Clicking sound would be from lug bolts hitting emergency brake shoes and is caused when longer lug bolts are used or with new wheels on which your old lug bolts stick out too far. Lug bolt should stick out about 16-17mm from back of wheel.
For adjusting emergency brake shoes see this thread, last post.
https://mbworld.org/forums/e-class-w...-cv-boots.html
Good luck.
Good luck.
1 Post
ml/e420/others
did not put on new wheels nor changed the bolts
these are the same amgs and bolts that came on my car.
even today i put my full size spare on that i mounted on the right side before and the same noise..
thanks on the help richard.
U use a metal valves in your wheels? sometimes a miss lug inside the wheel produce this noise. Comonn when you use a metal valve & broken un unmounting the tire or missng lug inside. Check
Fabio Daniel
Fabio Daniel
1 Post
ml/e420/others
clicking stop and NOW this noise????????????????????????????????????????
http://tinypic.com/player.php?v=j8f6o6&s=5
dragging pad ? any visible particulates on rotor or pads? have you had a
chance to pull the tire/rim combo and examine everything again?....including
rotating by hand? how about removing wheel, rotating it 90º and putting
it back on and seeing if sound still exists?
sounds somewhat to me to be hub/wheel rotationally generated, for sure
