climate control: stuck in ec mode
Old Jun 12, 2010 | 08:58 PM
speedn_j's Avatar
06 s500, 95 e320, 01 e430
was driving down the highway with the a/c on and then noticed that the a/c was off and back in ec mode. now i cant get it off the ec mode.everything was working perfectly till this happened. is there any obivious things i should look at? can anyonne point me to threads i missed during my searches? maybe the relay? the climate control seems to function normally minus the a/c.
1999 e300 turbo diesel 213k miles
Old Jun 12, 2010 | 09:48 PM
speedn_j's Avatar
ok just noticed the thread below on the same thing.
e codes:
61221
61231
61234
61453
61424
61241
sensor codes:
1 102 inside temp
2 114 outside temp
3 102 left heater core temp
4 100 right heater core temp
5 143 evap temp
6 181 engine coolant temp
7 10 refridge pressure
8 148 refridge temp
now i have a cel after retreaving the codes. yay
Old Jun 13, 2010 | 02:19 AM
saintz's Avatar
GL450
Pull the codes. Reset them. See if it works. Lookup the codes. You can find good diagnostic information if you google MBworld.org and benzworld.org.
