1998 e430: Should passngr mirror lower itself in reverse?
2003 s500 sport
When you back up in parallel parking should the passanger mirror tilt down by itself to see the curb better? I don't think mine does that but it moves for some reason when I press the right side mirror adjustment button right after backing up.
Sometimes they get stuck if the mirror wa manually moved to one extreme postion or another. Try moving it all around using the joystick, center it, then go in reverse.
If that doesn't work, it might be bad.
