engine codes..
Old Mar 27, 2011 | 07:19 PM
onewylchyl's Avatar
2000 e320
engine codes..
How do I clear the engine codes on a 2000 e320? hand held scanner shows codes cleared and then states one code remaining...it won't clear..any ideas?
Andy
Old Mar 27, 2011 | 07:41 PM
ohlord's Avatar
A. What's the code
B. If the problem is not cured the code will remain.
Your problem remains
We can't solve it with no information
Neither. Can you
Old Mar 28, 2011 | 10:07 AM
onewylchyl's Avatar
2000 e320
It is showing cylinder 1 misfire. I changed coil, plugs and wires. The code wont clear even without starting engine. Code reader says code erased and one code remaining.
Old Feb 16, 2020 | 12:59 AM
Benzito95's Avatar
C230 M272 2007 AMG
hi the u might have to open the valve cover and inspect the valves on cylinder one, they might have gone sticky, I had once fixed that issue by steaming the valves but its a very tactical process, u can check for valves steaming on Google that might help.
