SPACERS ?? what size ??
Old Jul 21, 2011 | 01:31 PM
ollie payne's Avatar
w210 E320cdi
hi guys, i am thinking of spacing the wheels on my w210 out a bit to come closer to the edge of the arches.. i have staggered amgs and wonder what would be the best spacers to get or is it a trial and error kind of thing ??
Old Jul 21, 2011 | 01:36 PM
Staff@RPM's Avatar
Former Vendor of MBWorld
I would recommend at least 10mm and as high as 15mm depending on how aggressive you want to be.
If you need them I should have every option in stock. Those sizes will all be HubCentric as well so you wont have any vibration whatsoever with that set up.
Let me know if you need any help or pricing. It's amazing how much better the car looks with an aggressive stance.
Old Jul 21, 2011 | 01:41 PM
w210 E320cdi
now that was just the reply i was looking for ! will i contact you PM or do you have an email address ?
Old Jul 21, 2011 | 01:48 PM
ohlord's Avatar
Measure
twice,install once.
You will need custom lugs. Be sure to leave enough clearance up front for curb turning and speed bumps.
What offfsets and tires size are you running?
Is the car lowered?
Old Jul 21, 2011 | 02:07 PM
w210 E320cdi
Originally Posted by ohlord
twice,install once.
Is the car lowered?
not 100 % on the offsets, wont say in case im wrong, will have to check,
have 18" monoblocks 235/40 front and 265/35 rear
the car is not lowered, well its an avantgarde so it is a bit lower than standard rite ?
Old Jul 21, 2011 | 02:09 PM
Staff@RPM's Avatar
My email address is staff@rpmnorth.com or you can always just call as well.
Old Jul 21, 2011 | 03:59 PM
raymond g-'s Avatar
99 E320
i'm not so quick to pronounce that spacers are needed, or desirable. generally,
the AMG monoblocs are like ET31 in front and ET 35 in rear. rear usually does
not produce any rubbing problems. however, the front combination of offset,
wheel width (guessing 8.5") and 235 tire cross section are already pushing the
limits of allowable ET. should you push it out even more, e.g. 10 or 15mm, you
are courting wheel arch/lip rub on the outside tread of the tire. on straight and
smooth pavement, rubbing and scoring may not occur. but once you are in
turns, or induce serious pavement undulations, contact is likely. proceed
carefully, I opine.
Old Jul 21, 2011 | 06:31 PM
w210 E320cdi
carefully, I opine.
that offset sounds about right.. 8.5 on the fron and 10" on th rear.. like you say there is absolutely no rubbing no matter what weight is in the car or what type of road i travel, however i do love the stance that the extra bit of "width" can give to the car.. maybe i should wait until i lower it another small bit and see then.. but even then if there is fouling of the arch i will only be delighted to have to go and get the arches rolled to make sure the wheels fit up inside them nicely.. i know that this is not to most peoples desired taste but i love them low
