Do I need to code this part or something?
Old Sep 11, 2011 | 02:44 PM
marcosv's Avatar
96 E320
Hello folks,
I own a E320 96 and
I was having an issue with my driver’s side window that was with no power to lower it.
I bought this used part (electrical module # 2108203926) on e-bay and after installing it my drivers side window works just fine, but now I’ve a problem with the other 03 windows, trunk switch, turn signal & wiper.
What would be the problem any suggestion?
Old Sep 11, 2011 | 11:02 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
No it doesn't need coding but anything but the exact right part will probably give electrical problems.
Old Sep 13, 2011 | 03:37 PM
dsmith's Avatar
88 535is, 89 318iT
Did you disconnect/reconnect the battery during the repair? If so, then you reset the system so the window worked and now others don't. My bet is that you guessed at what was wrong and didn't replace the problem module.
