windows making noise
Old Jul 7, 2003 | 03:17 AM
Alexbenz's Avatar
Sean's Sister--
hey guys on my passenger side on my car, when i roll down the windows not even half way or if i roll it up it makes a settle noise or creaking noise but for only 10-15 secs? it seems maybe its lose but i have no idea, what do you guys think? any ideas
thanks
Old Jul 7, 2003 | 10:51 AM
aglasgow's Avatar
1997 E420 Sport
try having the window rails lubricated first. It's probably not the motor as when they go bad, they tend to just stop working at all. If you feel comfortable taking the door panel off, you can do this yourself.
Old Jul 7, 2003 | 01:59 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Re: windows making noise
thanks
I Have Repaired Several of the Squeaky Window Compalints
It is The White Plastic Block that Goes on the Window Regulator to the Window Rail at the Bottom of the Glass.. Remove the Door Panel and Replace the Plastic Piece and NO more Squeak!
Old Jul 8, 2003 | 02:58 AM
Alexbenz's Avatar
Sean's Sister--
thanks for the help guys, i will try it out and see what happens.
Old Oct 31, 2008 | 01:12 PM
Rostam's Avatar
97 420
What is this White Plastic Block called, so I can order it from the dealer?
