removing reardeck, rubber pads?
Old Jul 9, 2003 | 01:08 PM
dallasdriver's Avatar
99 e430 Green
ok, I need to figure out a way to pull out these, about inch thick rubber pads from where I understand the factory woofers could go. They are coving what looks to be a 6.5 in speaker. The guy at the audio shop says he can get them out in about an hour, but he thinks he will have to take out the rear deck lid, and im thinking yall have got to know some easy way to get this done. I would like to keep the rubber intact or know a place to buy another set for when I take my system out, so I won't hear rattles in the trunk.
Old Jul 9, 2003 | 01:40 PM
Benz's Avatar
2000 F-150 XLT Sport Crew Cab
I'm not 100% sure on what your talking about, but to get under the rear deck it has to be removed. When getting removed you have to take out all 3 headrests.....They are very easy to remove but can be a pain if never done before.
You can pop your reardeck up but only so far with the headrests on. Maybe you can lerk under there to look around....No bolts are there to be taken off for the reardeck....Just pull it up.
I hope this helped some.
