99 E320 transmission adaptation procedure
1999 E320
Does anyone have the transmission adaptation procedure that needs to be done after installing a replacement transmission (used but good) and erasing the codes in ETC ? I checked the sticky notes but couldn't find anything. Thanks.
I regret to advise that to be done correctly you will need a shop has DAS Xentry(Star) diagnostic software or equal. That type of software will read/clear the faults in the transmission module plus the faults stored in the ECU(check engine) and do the control module adaption process. Good Luck!!
1999 E320
Thank you for the info. I intent to purchase a carsoft 7.4 multiplexer which I heard that it should do this job. Just don't have the money to pay the dealership for 2 hours of their time ($140 per hour) to correct this problem.
