power steering hose bolt broke
Old Dec 22, 2012 | 08:03 PM
edkaeser's Avatar
e320
I have a 1999 E320 that had a power steering hose leak. I bought a new one, installed it but the connection at the rack and pinon leaked. I began tightening the bolt (very hard since space is SO tight!) still leaked, tightened again... bolt broke. Luckily I was able to use my "back outs" to remove the bolt.
Can anybody help me with why the metal hose connection leaks? I have the copper seals and tightened the bolt very tight.
HELP!
Old Dec 23, 2012 | 10:37 AM
Fabio D's Avatar
210 55
Replace the cooper seals by a new ones, i got the same issue in my car some years ago and replacing the cooper seals solve the problem
Fabio Daniel
Old Dec 23, 2012 | 02:30 PM
edkaeser's Avatar
e320
Originally Posted by Plutoe
Where did you buy the hose and did you compare the ends before install.
I bought the part online. I did see that the hoses looked alike and that the bend in the metal was the same. However, I did not look at the metal round connector part in detail. I guess that could be a problem. I was wondering if other part "down there" are potential leaks areas. Seem be a lot of parts that could leak as well. Any suggestions?
Thanks for your input VERY much! Ed
Old Dec 23, 2012 | 02:32 PM
edkaeser's Avatar
e320
Fabio Daniel
I did put new copper seals on. I was wondering if there are other parts "down there" that are potential leak areas for a 1999 E320?
Thanks for the input! Ed
