Intermittent Vibration
Old Mar 18, 2013 | 12:07 PM
welcha's Avatar
2002 E430
Hi All. My '02 E430 has a vibration when I get into top gear - anything above 50 or so. Accelerating or decelerating, neutral throttle - doesn't matter. It is intermittent every 5 seconds or so for perhaps 1-2 seconds. I have had the motor mounts replaced recently, and have brand new tires on it. It come from the undercarriage is as close as I can narrow.
My Mechanic (independent shop) is perplexed as well, and has ridden in it with another mech to try to isolate the source, to no avail.
Any/All ideas welcome. Tired of driving the 98 C230 all the time!
Thanks, Alan
Old Mar 18, 2013 | 06:11 PM
mufc's Avatar
2006 CLS55
Vibration
You may want to check the flex joints on the drive shaft. One at the transmission and and the other at the differential. I had a vibration that was some what similar but worse under acceleration and I found it was caused by the rear flex joint. I changed both and now smooth as silk
Old Mar 18, 2013 | 06:23 PM
welcha's Avatar
2002 E430
Thanks. Unfortunately, mechanic has ruled those out as being in good shape...may have him double check anyway as he is totally perplexed. Thanks again, mufc.
