Right Rear Brake Pad worn at Severe angle??
Old Mar 30, 2013 | 06:26 AM
Little's Avatar
2001 E430 4matic
As I was driving home the other night I my brake pedal went to the floor so I limped it back to my shop. After putting it on a lift I found that the brake fluid was leaking from the caliper where the piston goes through the boot. I believe the piston is too far out due to the brake Pad being worn at an extreme angle. It looks like a right triangle. The driver side rear also is wearing at an angle but not nearly as severe. What is causing this? I know this can occur with dual piston calipers but on a single?
Old Apr 1, 2013 | 09:47 AM
lafamiliacustom's Avatar
E430 4matic
Im having the same problem on the wifes car. Ive noticed when changing the caliper the pistons arent flat there is a step on them. Im wondering if you have to line them up a certain way. Maybe? Anyway im taking her car in for an alignment today. Ill ask the tech about that and report back with hopefully an answer...
Old Apr 1, 2013 | 04:14 PM
Little's Avatar
2001 E430 4matic
Hmmm.. let me know if you come up with something. I won't be able to look at the car again till this wknd so hopefully we can figure out something soon. I hope my calipers are not bad.
