Air in
Secondary air intake. Where is it located? Does anyone no
Why are you asking??
Trouble code: P0411 and P1444= undefined code...? The cluster also shows batterie charge light . Beeps every 30 sec
p0411: secondary ari in detection system incorrect flow detected
The P0411 is the secondary air injection system(emissions related) fault. The system includes a motorized air pump, relay, switch over valve and aspirator shutoff valve.
The issue is P1444 which is the fault associated with the switch over valve. It is that valve that is faulty not the motorized pump. You need someone familiar with the system and your motor to show you the location of all those parts.(the motorized pump is typically above the alternator) In any event check all hoses and then clear the faults----then do the faults return---if they do you know you have to replace the air pump switch over valve. |
Originally Posted by Jtjt
(Post 5674344)
Does anyone have an alternator for sale? Also the gas needle doesn't work. It just shakes like if it was stuck. Wish there's a video for all repairs.
Air switch valve? I wouldn't n no where to start. Try to find books on all this but they all cost $ and I'm just a student
Yep I know the feeling. The good news is that after graduation you can start charging for your services!!
So this mbworld forum is just a site for service advertisement and finder?
(Post 5676930)
Good to know.
