W140 Monoblocks on W210 fitment issues
I've researched this topic and found some information but can't seem to find any solid answers or pictures. I was able to pick up a set of W140 monoblocks 18x8.5 et47 all around for a steal and am trying to figure out what size spacers I will need to run these and get them flush. I'm thinking maybe 20mm F and 25mm R?
The car is a 2000 E430 sport. I'm currently at stock height but will be on lowering springs eventually. Also debating whether to go with 235/40 or 235/35 tires. Any help is greatly appreciated! |
You're going to rub on the control arm bolt in the front with ET47 and 8.5 width. My setup with ET37 and 8.5 rubbed slightly with 235 40. Also, you'll need pretty large spacers to get even close to flush with those specs.
Here's my fronts, 18x8.5 ET20 (because of 15mm spacers): http://farm4.staticflickr.com/3674/9...1640e3e7_c.jpg DSC_0855 by fbaladad, on Flickr And my signature is the same specs, just lower. |
Thanks for the reply! It looks too like your fenders are rolled all around and slightly pulled up front. I haven't even checked to see if my sport has rolled fenders from the factory like the AMGs. I guess it's a possibility since it's the same body. Do you think 20mm front and 30mm rear would get close to flush?
And also, what size tires are you running now and how wide are your rear wheels if not the same as your fronts? |
Originally Posted by amusicianslife
(Post 5896590)
And also, what size tires are you running now and how wide are your rear wheels if not the same as your fronts? And I think 20mm front would get you pretty flush for the fronts, especially if you had 225 or 235. With my 25mm rear spacers, it brought my final offset to 10, which let me run 225/40 or 235/40 with rolled fenders. Currently, my wheels are 18x8.5 all around and I have 215/40 Continentals on. Let me know if you have any other questions :y |
A 15 or 20 mm spacer should get you close in the front.
I have same car same wheels and offsets as you (good to know they are from w140). it did hit control arm up front. I bought a 12mm spacer and its close but not flush with one coil cut in the front. im afraid 20mm would be mexiflush. I wish I would have gotten 15mm for front and 20mm for rear.
tires on mine are 225 40 f 245 40 r edit: I change my response, I think 20mm up front would be perfect |
A 20mm spacer would look good, especially if you are going to go lower. I thought 15mm looked great until I lowered it more, which gave me more negative camber in the fronts. lol
Thanks guys for the help! I think I'll try 20mm front since I am planning on lowering on springs eventually. The rears appear to have more room and would need bigger spacers to sit flush. Not sure if I should go 25 or 30mm R.
devo540- Do you have any pictures? It would be really helpful to see what your set up looks like. Did you have to roll your fenders? siopaolover- How much camber are you running now? I'd like to not go past -1.5 since this is my daily. |
(Post 5898213)
Thanks for all the help! Any recommendations on spacers? I know I need hubcentric but how long do the lugs need to be if my fronts will have 20mm and my rear will have 30mm spacers?
If by any chance anyone has pictures of a w210 on w140 monoblocks please post them! |
With K-MAC you can resolve both Front and Rear Camber, caster, Toe issues.
Ex-factory there is only front and rear Toe adjustment for virtually all Mercedes 1968 to current models (and same with Chrysler Crossfire and 300C etc).
We saw the need and were the very first company to manufacture precisely adjustable front Camber and Caster bushing kits with twice the adjustment range of the basic one setting offset bolts. Then for the rear, K-MAC Camber adjuster kits, which have the advantage (unlike upper adjustable arms/DIY kits) of not moving the top of the tire outwards when adjusting to resolve premature inner edge wear - which is an important factor to prevent tires scuffing outer fenders if wide profile tires/rims fitted. Another advantage with K-MAC rear kits - unlike spherical bearings used in these upper arm kits, there is no harsh metal to metal contact and 20 years of the proven design - there’s certainly no squeaks. Also all K-MAC rear Camber adjusters include extra Toe adjustment which is essential to compensate accurately for the new Camber facility! The K-MAC patented design front kits replace the 4 main suspension bushes - the unique 2 axis/self aligning design also doubles the load bearing area thereby increasing wear life and also steering and braking response. Similar design is used for the 4 main rear K-MAC bushings. Result is precise single wrench front and rear (ongoing) adjustment to return vehicle to factory specs to improve traction, compensate for steering pull, costly inner edge tire wear through altering height, fitting wide profile tires, load carrying, curb-knock damage and/or the advantage of being able to alter specs, improve lap times on track days and with genuine K-MAC you also do not need to purchase special fitting tools. Product confidence with K-MAC is further assured by our total, ongoing commitment to motor racing – all out 10/10ths competition testing keeps K-MAC products always at the forefront re cutting edge technology, proven strength and durability. |
